15 years ago
mmu libm error in atan2
I'm using nios2-linux-20100621.tar with my 3C120 Dev Board (ghrd.sof) and my statically compiled application is getting a segfault when I use the atan2 function in the math library from the binary mm toolchain.
root:/tmp> ./atan2_test 0 1
y = 0.000000
x = 1.000000
fabs (0.000000 / 1.000000) = 0.000000
atan (0.000000 / 1.000000) = 0.000000
atan (fabs(0.000000 / 1.000000)) = 0.000000
atan2 (0.000000, 1.000000) = 0.000000
root:/tmp> ./atan2_test 1 -1
y = 1.000000
x = -1.000000
fabs (1.000000 / -1.000000) = 1.000000
atan (1.000000 / -1.000000) = -0.785398
atan (fabs(1.000000 / -1.000000)) = 0.785398
SEGV
Although the atan function seems to work, it appears that the atan2 function dies trying to call it. We've also had memory leaks with printf when using %d or %f format specifiers.
To get past this, I've been reading all the threads about the mmu toolchain and it does not appear that anyone has ever successfully recompiled the mmu toolchain. Is this the case? I've seen a few notes that a common toolchain is coming but they were old (2009?). Can anyone help point me to a resource on how to rebuild the mmu toolchain?
1 Reply
    Any luck getting the atan2 to work? I also having same difficulty.
    Moganesh
