15 years agoMissing DSP builder standard blockset
I've tried to install the DSP builder standard blockset numerous times but all I can access in the Simulink browser is the advanced blockset. I'm using matlab r2010a, does any one have any ideas or k...
15 years agoHi,
I remember having a similar problem. For some reason the standard blockset may not have been added to you Matlab path. You can try going to the file menu, select "Set Path" and 'Add with sub-folders' all of the folders in the DSPBuilder folder (if these folders are not already included). Best Regards, RUSHALE
