12 years agomissing Displayport include soiurce files
I am working on the displayport transmit demo using the Opencore evaluation and ran into a problem rebuilding the NIOS project to test the design. After running the runall.tcl script to setup...
12 years agoI figured this one out on my own. It looks like they don't provide the source files so you need to add the library to the project file. The process for this is described in the software developers handbook under using the library. Also need to set up the timer in the BSP editor or errors will appear with the timestamp functions.
