15 years agomin max frequency requirement of altera IP components
Hi all, I have modified the standard project provided by the cycloneIII_3c120_embedded so that some of the components work at a lower frequency. Unfortunately while the project synthesizes with...
15 years agoHi again,
Cris is very right here. I tested to raise up the frequency of the CPU on a Cyclone III to 150MHz and failed. The 120MHz is a good value for the Cyclone III. A lot of the possible performance on the NIOS2 depends also on the points Cris noted for you! Sorry I forgot that point while I searched the table, thank you Cris!
