15 years agoMGL_INTERNAL_ERROR - Terasic's SFP loopback test
I downloaded Terasic's sfp_hsmb_s4gx_pcie_xcvr_loopback_6p25Gbps_restored project.
On compilation I get the following error: Error: MGL_INTERNAL_ERROR: Generator entity alt_cal is specified as a primitive with no parent. CAUSE : Top level entity is specified as a primitive or primitive has no parent. All primitive objects in clear box should have non-NULL parents and top level entities cannot be primitives. ACTION : The constructor of the entity still has the set_primitive () function, or the parent of the primitive object is set to NULL. I am using Quartus 10.1sp1. I much appreciate your help. Thank you!No RepliesBe the first to reply
