mem_reset_n always is low from DDR3 hard controller
Have you try to simulate your IP with the example design in your simulation?
At the moment, no, since there were no problems when using the core on Cyclone 5
- AdzimZM_Altera5 years ago
Can you give it a test?
So before this you're working on Cyclone V device and it's worked.
But now you try to implemented it in Arria V is it?
Do you create a new IP for the Arria V or you use the existing project?
- EBoln5 years ago
I copy qsys file with DDR3 controller from CycloneV project to ArriaV project, ofcourse i change FPGA type in qsys file
- EBoln5 years ago
And i try create new qsys with controller
Thanks for clarifying about your project.
I guess there is no error during the IP generating process and compilation.
But since you're facing some issue with the Arria V device, can you use the example design to simulate your IP in the Arria V?
