EBoln
5 years agomem_reset_n always is low from DDR3 hard controller
i have ArriaV, DDR3 chips, but after deassert global and soft resets mem_reset_n stay is low. Soft reset generate after 1000 tick on 100MHz clk
What else can affect this signal?
AdzimZM_Altera
5 years agoHave you try to simulate your IP with the example design in your simulation?
- EBoln5 years ago
At the moment, no, since there were no problems when using the core on Cyclone 5
- AdzimZM_Altera5 years ago
Can you give it a test?
So before this you're working on Cyclone V device and it's worked.
But now you try to implemented it in Arria V is it?
Do you create a new IP for the Arria V or you use the existing project?
- EBoln5 years ago
I copy qsys file with DDR3 controller from CycloneV project to ArriaV project, ofcourse i change FPGA type in qsys file
