17 years agoMegawizard pins do not match datasheets
I just ran the megawizard plug-in manager to create a interface with my DDR2SDRAM. The example design compiles, but the pins do not match the datasheet. I'm using the Cyclone II EP2C70. The ram u...
17 years agoHi Steven,
I am referring to all the values that you have to set in the Wizard! For instance the number of chip selects, the length of the burst, the memory timing etc! Did you set these values or didn't edit?
