17 years agoMegawizard pins do not match datasheets
I just ran the megawizard plug-in manager to create a interface with my DDR2SDRAM. The example design compiles, but the pins do not match the datasheet. I'm using the Cyclone II EP2C70. The ram u...
17 years agoHi,
I use the same board and the same ram and it works fine! Did you edit the "constraint" in the MegaWizard?
