CPete12's avatar
CPete12
6 years ago
MAX10 Design Security
Dear forum members,
I have three questions regarding MAX10
Question 1: Allow encrypted POF only
If I enable encrypted POF, I am able to re-programm the FPGA at a later stage with a non-encrypted POF. This does not make sense to me, can you please comment on this issue.
Question 2: Enable JTAG Security
It is my understanding that enabling JTAG security means that I cannot reprogram the FPGA. The exception would be if I were to use JTAG Secure Unlock via internal JTAG WYSIWYG. However, I have not installed this feature. My question is: Is internal JTAG WYSIWIG is disabled by default or do I need to disable it?
Question 3: Verification of JTAG Secure
Is there an easy way to test if JTAG secure is applied?
Many thanks for clarifying,
Christian
  • YuanLi_S_Intel's avatar
    YuanLi_S_Intel
    Please find my response below:
    Nope, this is wrong. You cannot program non-encrypted POF once JTAG Secure is enabled.
    Nope, this is not enabled by default. You may refer to user guide below for the method to enable it:
    https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an556.pdf (Page 36)
    If you have the external header to connect with JTAG. The easiest way is to try to access using that. It will not be able to access if JTAG secure is enabled.
    Thank You.
    Bruce
    • CPete12's avatar
      CPete12
      Dear Bruce,
      Thank you very much for getting back to me. Everything clear, except one misunderstanding:
      For questions 1: I can select "Allow encrypted POF only" and NOT "Enable JTAG security". (see attachment) I was able to later program with a non-encrypted file. Therefore, I do not see any effect of chosing "Allow encrypted POF only". Can you please elaborate on this.
      Cheers,
      Christian
    • CPete12's avatar
      CPete12
      Dear Bruce,
      Did you receive my later response / question?
      Cheers,
      Christian
    YuanLi_S_Intel
    If you have enabled this option, that means to say the encrypted POF can only be configured into internal flash. However, programming the CRAM is still posssible. Thus i am assuming you are programming the CRAM instead of the internal flash with unencrypted POF.
    Thank You.
