MAX10 Design Security
Please find my response below:
Question 1: Allow encrypted POF only
If I enable encrypted POF, I am able to re-programm the FPGA at a later
stage with a non-encrypted POF. This does not make sense to me, can you
please comment on this issue.
Nope, this is wrong. You cannot program non-encrypted POF once JTAG Secure is enabled.
Question 2: Enable JTAG Security
It is my understanding that enabling JTAG security means that I cannot
reprogram the FPGA. The exception would be if I were to use JTAG Secure
Unlock via internal JTAG WYSIWYG. However, I have not installed this
feature. My question is: Is internal JTAG WYSIWIG is disabled by default
or do I need to disable it?
Nope, this is not enabled by default. You may refer to user guide below for the method to enable it:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an556.pdf (Page 36)
Question 3: Verification of JTAG Secure
Is there an easy way to test if JTAG secure is applied?
If you have the external header to connect with JTAG. The easiest way is to try to access using that. It will not be able to access if JTAG secure is enabled.
Thank You.
Bruce
Dear Bruce,
Thank you very much for getting back to me. Everything clear, except one misunderstanding:
For questions 1: I can select "Allow encrypted POF only" and NOT "Enable JTAG security". (see attachment) I was able to later program with a non-encrypted file. Therefore, I do not see any effect of chosing "Allow encrypted POF only". Can you please elaborate on this.
Cheers,
Christian
