17 years agomax data rate calculation for NIOS II
Hi, i want to know how to calculate the max data rate that a NIOS II processor can read from a PIO interface. As far as i understand, i think it depends on core frequency of NIOS II and also may b...
17 years agoIt depends on a few factors, and I'm not sure you can get a constant value for this.
Like you mentioned, Nios II frequency and instruction cycles play a role. You can also look at the latency from the PIO, which I believe is 1 cycle. Next is the system architecture. The arbitration within the bus will affect the latency of data coming back. Your best bet is to use tightly-coupled memories for the CPU data and instruction, have direct connections to your PIO without going through bridges, etc.
