Max 10 Triple Speed Ethernet UDP reference design\training\documentation
Hi
I have the DK-DEV-10M50-A MAX 10 development board, which amongst other things feature a couple of LAN connectors and associated PHY.
I’d like to get UDP working using the appropriate qsys platform and NIOS II simple socket templates, but unfortunately and after a few frustrating days I’m struggling to find any documentation that is current or a reference design that works. For now this is an evaluation project (i.e. Quartus lite), and everything I find is either out of date, does not build, missing files, or requires licenced components to build (I was hoping for a time limited sof file).
If anyone can point me in the right direction I’d be very grateful.
Thanks in advance
David
- Deshi_Intel
HI David,
Below is the closet that I can find on Max 10
dlim
- DavidCambridge
Thanks for the link - unfortunately I've already tried and failed with these examples. When I try and compile I get numerous errors all reporting that the licence is not available for various files. That put's me in a bit of catch 22, because we wouldn't want to get a licence until we can evaluate!
David
- DavidCambridge
With reference the above, I think I've solved the problem of not having a licence. The solution is below:
For anyone reading in the future, and if the link above is broken, go to Assignments (top menu)\Settings\Eda Tool Settings and set Simulation to "none". This removes the need for the licences components.
David
- Deshi_Intel
Hi David,
Sorry, this is the only one that I can find so far.
Let's see if there is respond from other forum user that may come across similar example design that can share more info here.
dlim
