HI David,
Below is the closet that I can find on Max 10
dlim
Thanks for the link - unfortunately I've already tried and failed with these examples. When I try and compile I get numerous errors all reporting that the licence is not available for various files. That put's me in a bit of catch 22, because we wouldn't want to get a licence until we can evaluate!
David
- DavidCambridge5 years ago
With reference the above, I think I've solved the problem of not having a licence. The solution is below:
For anyone reading in the future, and if the link above is broken, go to Assignments (top menu)\Settings\Eda Tool Settings and set Simulation to "none". This removes the need for the licences components.
David
Well, If I use the prebuilt files shipped with the version 17.1 reference design then I can get my board to work with UDP (using this reference design below).
Unfortunately, the qsys file supplied will not regenerate (many errors), and the NIOS II build will not recompile (the par file seems to come with the eclipse project already built - the prebuilt files work, but the source code won't compile).
I'll keep you posted if I ever get it to work, but in the mean time it's also back to my original question , which is to ask if anyone knows of a sample project \ refence design that works ?
Thanks again
David
