15 years agomatrix operation in vhdl
Dear all, Can anyone give me a simple code for matrix operation such as multiply, add, substract or etc.? I am new with vhdl. Many thanks
15 years agoThis is the code i write and actually i want to has a matrix transpose from row to column.
library ieee; use ieee.std_logic_1164.all; entity transpose is port ( -- Inputs in1 : IN integer RANGE -127 TO 127; in2 : IN integer RANGE -127 TO 127; in3 : IN integer RANGE -127 TO 127; --Outputs out1 : OUT integer RANGE -127 TO 127; out2 : OUT integer RANGE -127 TO 127; out3 : OUT integer RANGE -127 TO 127; end transpose; architecture transpose of transpose is type column is range -127 to 127; type row is range -127 to 127; type matrix is array (row,column) of integer; variable prod : matrix; variable i,j : integer; begin process begin for i in -127 to 127 loop for j in -127 to 127 loop prod (i,j)<= prod (j,i); end loop; end loop; end process; end transpose; I think the error is at the array structure.Can you tell me what am wrong? Many thanks
