Matlab automatic exit, when I click on Compile
OS: Windows 7sp1 Ultimate(32bit)
Altera Quartus II : 12.0sp2 (32bit)
Altera DSP builder: 12.0sp2(32bit)
Matlab: MATLAB R2012a
Simulink simulation done right, double-click the Signal Compiler, click Compile, matlab quit immediately. Excuse me, this is what reason?
I guess that is a software BUG, but I should how to solve?
Project directory added a TXT documents, in matlab out and content are as follows:
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x74be29de, pid=7440, tid=4596
# JRE version: 6.0_17-b04
# Java VM: Java HotSpot(TM) Client VM (14.3-b01 mixed mode windows-x86 )
# Problematic frame:
# V [jvm.dll+0xb29de]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
--------------- T H R E A D ---------------
Current thread (0x06639000): VMThread [stack: 0x0d740000,0x0df40000] [id=4596]
siginfo: ExceptionCode=0xc0000005, reading address 0x79706f67
Registers:
EAX=0x00000000, EBX=0x00000000, ECX=0x79706f63, EDX=0x0b6525c0
ESP=0x0df3f6c4, EBP=0x0df3f6cc, ESI=0x0df3f6dc, EDI=0x0df3f70c
EIP=0x74be29de, EFLAGS=0x00010246
Top of Stack: (sp=0x0df3f6c4)
0x0df3f6c4: 00000000 0657f800 0df3f7d4 74cfe26d
0x0df3f6d4: 0df3f6dc 0df3f70c 00cf69c8 68676972
0x0df3f6e4: 00000000 00000000 79706f63 20676e69
0x0df3f6f4: 00cf69c8 68676972 00000000 00000000
0x0df3f704: 79706f63 20676e69 755e17c4 b9038299
0x0df3f714: 000003e8 0ba7f4a3 0ba7f2a6 07f5f3f8
0x0df3f724: 0ba7f4a2 74d22518 0df3f78c 74cc21a9
0x0df3f734: 0ba7f4a2 74d22518 74bb6763 06639330
Instructions: (pc=0x74be29de)
0x74be29ce: e8 dd fe ff ff 5f 8b c6 5e 5d c2 08 00 8b 49 10
0x74be29de: 8b 51 04 8b 01 52 83 c1 08 50 51 8b ce e8 f0 70
Stack: [0x0d740000,0x0df40000], sp=0x0df3f6c4, free space=8189k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
V [jvm.dll+0xb29de]
V [jvm.dll+0x1ce26d]
V [jvm.dll+0x1ce587]
V [jvm.dll+0x1e8722]
V [jvm.dll+0x1e8ca2]
V [jvm.dll+0x173e4c]
C [MSVCR71.dll+0x9565]
C [kernel32.dll+0x4ed6c]
C [ntdll.dll+0x6377b]
C [ntdll.dll+0x6374e]
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x1e9e5c00 JavaThread "Thread-76" [_thread_blocked, id=2580, stack(0x20820000,0x208a0000)]
0x1e9e6800 JavaThread "Swing-Shell" daemon [_thread_blocked, id=2920, stack(0x207a0000,0x20820000)]
0x1e9e6000 JavaThread "Explorer NavigationContext request queue" [_thread_blocked, id=7456, stack(0x0fd40000,0x0fdc0000)]
0x1e9e3c00 JavaThread "Timer-6" daemon [_thread_blocked, id=6024, stack(0x259d0000,0x25a50000)]
0x1e9e2000 JavaThread "AddressBar directory emptiness poller" [_thread_blocked, id=3944, stack(0x20a10000,0x20a90000)]
0x1e9e1400 JavaThread "Timer-1" [_thread_blocked, id=6964, stack(0x0fc70000,0x0fcf0000)]
0x1e9e0c00 JavaThread "TimerQueue" daemon [_thread_blocked, id=6568, stack(0x09ab0000,0x09b30000)]
0x1e9e0800 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=6332, stack(0x0fde0000,0x0fe60000)]
0x1e9e0000 JavaThread "AWT-Shutdown" [_thread_blocked, id=792, stack(0x0fbe0000,0x0fc60000)]
0x1e8f2800 JavaThread "FelixPackageAdmin" daemon [_thread_blocked, id=6684, stack(0x088a0000,0x08920000)]
0x1e905800 JavaThread "FelixStartLevel" daemon [_thread_blocked, id=1256, stack(0x0f9e0000,0x0fa60000)]
0x1e905400 JavaThread "FelixDispatchQueue" daemon [_thread_blocked, id=7116, stack(0x0f910000,0x0f990000)]
0x1ea74400 JavaThread "com.google.common.base.internal.Finalizer" daemon [_thread_blocked, id=1236, stack(0x0e170000,0x0e1f0000)]
0x1e909c00 JavaThread "AWT-Windows" daemon [_thread_blocked, id=7632, stack(0x0eaa0000,0x0eb20000)]
0x1e909000 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=7176, stack(0x06210000,0x06290000)]
0x1e5e1400 JavaThread "Timer-0" [_thread_blocked, id=6536, stack(0x07f90000,0x08010000)]
0x0f477000 JavaThread "EventMgr Dispatcher" daemon [_thread_in_native, id=6160, stack(0x06f00000,0x07700000)]
0x06683c00 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=7052, stack(0x06150000,0x061d0000)]
0x06655c00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=8096, stack(0x0e250000,0x0ea50000)]
0x06655000 JavaThread "Attach Listener" daemon [_thread_blocked, id=600, stack(0x06010000,0x06090000)]
0x0663e400 JavaThread "Finalizer" daemon [_thread_blocked, id=2388, stack(0x089c0000,0x08a40000)]
0x0663cc00 JavaThread "Reference Handler" daemon [_thread_blocked, id=2552, stack(0x07ee0000,0x07f60000)]
0x0657f800 JavaThread "main" [_thread_in_native, id=8128, stack(0x00500000,0x00d00000)]
Other Threads:
=>0x06639000 VMThread [stack: 0x0d740000,0x0df40000] [id=4596]
0x06688c00 WatcherThread [stack: 0x0ec30000,0x0f430000] [id=6156]
VM state:at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: ([mutex/lock_event])
[0x0657e9d0] Safepoint_lock - owner thread: 0x06639000
[0x0657ea38] Threads_lock - owner thread: 0x06639000
Heap
def new generation total 18560K, used 5745K [0x10010000, 0x11430000, 0x12010000)
eden space 16512K, 22% used [0x10010000, 0x103ac530, 0x11030000)
from space 2048K, 100% used [0x11230000, 0x11430000, 0x11430000)
to space 2048K, 0% used [0x11030000, 0x11030000, 0x11230000)
tenured generation total 61668K, used 37438K [0x12010000, 0x15c49000, 0x18010000)
the space 61668K, 60% used [0x12010000, 0x1449fb28, 0x1449fc00, 0x15c49000)
compacting perm gen total 41984K, used 41858K [0x18010000, 0x1a910000, 0x1e010000)
the space 41984K, 99% used [0x18010000, 0x1a8f0a00, 0x1a8f0a00, 0x1a910000)
No shared spaces configured.
Dynamic libraries:
0x002f0000 - 0x0031b000 F:\matlab\bin\win32\MATLAB.exe
0x77450000 - 0x7758c000 C:\windows\SYSTEM32\ntdll.dll
0x77370000 - 0x77444000 C:\windows\system32\kernel32.dll
0x755e0000 - 0x7562b000 C:\windows\system32\KERNELBASE.dll
0x7ef10000 - 0x7efc0000 F:\matlab\bin\win32\libut.dll
0x7dce0000 - 0x7dd54000 F:\matlab\bin\win32\libmwi18n.dll
0x10000000 - 0x10009000 F:\matlab\bin\win32\libmwresource_core.dll
0x70ca0000 - 0x70d2e000 C:\windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a 1e18e3b_9.0.30729.5026_none_508eda5cbcbc08a8\MSVCP 90.dll
0x712d0000 - 0x71373000 C:\windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a 1e18e3b_9.0.30729.5026_none_508eda5cbcbc08a8\MSVCR 90.dll
0x736b0000 - 0x736d3000 F:\matlab\bin\win32\boost_filesystem-vc90-mt-1_44.dll
0x73f70000 - 0x73f77000 F:\matlab\bin\win32\boost_system-vc90-mt-1_44.dll
0x75af0000 - 0x75b90000 C:\windows\system32\ADVAPI32.dll
0x76c60000 - 0x76d0c000 C:\windows\system32\msvcrt.dll
0x77590000 - 0x775a9000 C:\windows\SYSTEM32\sechost.dll
0x76bb0000 - 0x76c51000 C:\windows\system32\RPCRT4.dll
0x73550000 - 0x7356f000 F:\matlab\bin\win32\LIBEXPAT.dll
0x72eb0000 - 0x73035000 F:\matlab\bin\win32\icuin44.dll
0x7ea10000 - 0x7eb2f000 F:\matlab\bin\win32\icuuc44.dll
0x00d00000 - 0x01b41000 F:\matlab\bin\win32\icudt44.dll
VM Arguments:
jvm_args: -Xss512k -XX:PermSize=32m -Xms64m -XX:NewRatio=3 -XX:MaxPermSize=96m -Xmx128m -XX:MaxDirectMemorySize=1200000000 -Dsun.java2d.noddraw=true -Dsun.awt.nopixfmt=true -Xshareff -Xrs -Dsun.awt.disableMixing=true -Djava.library.path=F:\matlab\bin\win32 vfprintf abort
java_command: <unknown>
Launcher Type: generic
Environment Variables:
PATH=F:\altera\quartus\bin;C:\windows\system32;C:\ windows;C:\windows\System32\Wbem;C:\windows\System 32\WindowsPowerShell\v1.0\;C:\Program Files\Dell\DW WLAN Card;C:\dell\ATI Technologies\ATI.ACE\Core-Static;F:\matlab\runtime\win32;F:\matlab\bin;C:\Pr ogram Files\Microsoft SQL Server\100\Tools\Binn\;C:\Program Files\Microsoft SQL Server\100\DTS\Binn\;F:\altera\modelsim_ase\win32a loem
USERNAME=ZH
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 37 Stepping 5, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 7 Build 7601 Service Pack 1
CPU:total 4 (8 cores per cpu, 2 threads per core) family 6 model 37 stepping 5, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, ht
Memory: 4k page, physical 2022080k(502172k free), swap 4044160k(1491124k free)
vm_info: Java HotSpot(TM) Client VM (14.3-b01) for windows-x86 JRE (1.6.0_17-b04), built on Oct 11 2009 00:52:06 by "java_re" with MS VC++ 7.1
time: Thu Jan 03 17:58:53 2013
elapsed time: 2428 seconds
Please note: my computer processor is i3 380M.And is not As described in the document red part.
