17 years agomaster other than NIOS cpu
hi all,
I am using Quartus SOPC builder to make a system. But I am using my microcontroller(8051) as cpu. For that if i connect a single slave, it is working fine but if connect more than one, none of them work. What may be the problem? Thank you.2 Replies
it's a good question, I'm guess this room almost amateurs so they can't answer you :) !!!
1 - Are you obeying the waitrequest rule?
2 - Is your address map correct? What is the failure mode? In what way is it "not working"? Jake
