15 years agoMarvell 88E1111 PHY question
I am using cycloneIII board with Marvell PHY RGMII interface. After searched around forum, I found suggestions that in order to receive frames successfully, the bit7 of mdio register 20 should be set...
15 years agoNo, it depends on how you specify the timing requirements on the FPGA side.
