16 years ago
Lvds Vs Ddr
Hi all, I have a question.
I have a design using lvds interface. Currently it is implemented with ALTDDR_in IP but no ALTLVDS. The input of ddr_in is mapped to a pin labeled with LVDS in pin assignment.
Now I see something about the ALTLVDS IP, and it can be used with the same function as ddr_in. I wonder which way is more efficient, in the power point of view.
Thanks~~~~~~~~~~:)
    What's your SERDES rate? If it's /1 or /2, then the altlvds megafunction will build it's logic out of the altddio primitives, and it's essentially the same thing. If it's a larger factor, say /4, then the dedicated LVDS logic is used. It will have better timing margins and dedicated for LVDS. (From a power point of view, I'm guessing it should be lower power, but probably not in a measurable manner. They're both using dedicated structures in the silicon, and should be insignificant in the grand scheme of things.)
    Dedicated SERDES hardware is only provided with Stratix and Arria FPGAs. On Cyclone chips, ALTD_LVDS uses software SERDES based on DDIO hardware.
    --- Quote Start ---
    Thanks~~~~~~~~~~:)
    --- Quote End ---
    Another question. Does LVDS has a high impedance output state besides '0' and '1'. Because it consumes a lot static power......
    Thanks~~~~~
