LVDS SERDES
I have IP serdes in my FPGA (FPGA A) -
This SERDES have connection with another FPGA (other board - FPGA B)
According to my project requirements - I should inject(output) and get(input) clocks from FPGA A to FPGA B
My question is : Should I place both clocks (in & out ) in the dedicated pin clocks or maybe I should do it only for the input clock ?
Yishay
Thanks for the details. Output clock at FPGA A can be placed at any LVDS pair pins and input clock at FPGA B should be sufficient.
Thank you.
- AminT_Intel
There is not enough information about your design but as far as I understand you can put both in and out in the dedicated pin. I'd advise you to check on both conditions you mentioned to see which one works.
- ymiler
Contributor
I drew a little VISIO that describe my design :
My problem is : Unlock / Lock indication is depend by FPGA loading
I wonder if the root cause is pin location -
Note : I dont have the option to locate input & output to SERDES pin dedicated clocks ( because board planning)
- AminT_Intel
Thank you.
