10 years ago
LPM Shift Reg ( Shifting Issues)
Hi all,
I have read the megafuction for the LPM Shift Reg.
Is it possible to set the amount of shifts you want in the shift register?
I plan to implement a left shift by 6 on a shift register for my design.
1 Reply
    --- Quote Start ---
    Hi all,
    --- Quote End ---
    Do you actually need a shift, or can you get the same benefit by just wiring differently? There's no real reason to use a shift megafunction if the shift stays constant; just wire the bits you want to the MSB, and fill the lower bits with whatever else you want.
