17 years agolocal_size in DDR2
Hi, I can pulse data through the DDR2 (native) controller, but I wonder if I can do burst reads and writes. While looking at the diagram on the DDR and DDR2 Compiler User Guide, I see in t...
17 years agoHi,
Since local bus width is twice as much as ddr2 bus width, the local size is half of ddr2 burst length. So if you set burst length as two in the megawizard, local size is always one. Then the bit width of local size is one. Setting burst length as four, you can choose one or two for local size. Thanks
