15 years agoLicensing Troubles
we have a problem here or some misunderstanding on the Altera Licensing concept: We have used the CRC Compiler in a design and now we cannot generate programming files because of the license missing. When opening up the License Setup Dialog I see the license type to be "Full Version", expiration 2011.10, Host ID NIC and I see a bunch of licensed Megacore Functions but the CRC Compiler is not included. I am quite confused, hopefully someone can answer me these questions: - What kind of license do we need to generate programming files with the CRC Compiler? - Where do we obtain that license and how much will it cost (just an estimation)? - Does obtaining such a license take as long time as obtaining the full license (3 weeks)? Because we simply do not have three weeks in our situation. - How can I avoid using restricted Megacore functions? FPGA primitives such as DDR or BRAM elements do not need a license, I did not see a real difference in the MegaWizard plugin manager between such a function and the CRC compiler. Really, I am a bit p***ed off at the moment, we paid 4k dollars for that full license and now there are still troubles with it. Best regards, flintstone3 Replies
Did you actually buy a licence for this? (Altera order code: IP-CRC).
A saw a € 1500,- tag at EBV. If you do not need the ultimate speed you can find alternatives-> OpenCores.org easics (http://www.easics.com/webtools/crctool) and others ... - Altera_Forum
Uh oh, so it looks like we had a misunderstanding on the licensing concept. We really need NIOS 2 and the TSE_MAC and as I understand it now this will cost extra (and furthermore take time to obtain the license that we do not have).
Best regards, flintstone - Altera_Forum
The smallest NIOS CPU is free if you have a recent version of Quartus, and there is an opensource alternative to the TSE mac on Opencores. Have a look at this thread (http://www.alteraforum.com/forum/showthread.php?t=21005)
