13 years agoLicense problem
Hi ! I am new at altera FPGA devices.I have a quartus 2 web edition.As I read from altera documents, after relasing the 8.1 version of quartus program,there is no license file for web edition q...
13 years ago --- Quote Start --- Do The following messages show that the pci_t32 will work fine ? Warning (12188): OpenCore Plus Hardware Evaluation feature is turned on for the following cores Warning (12190): ""PCI Compiler" (6AF7_0024)" will use the OpenCore Plus Hardware Evaluation feature --- Quote End --- No, that shows that Quartus doesn't recognise your license. When you link to the license file in Quartus -> Help -> License Setup (I think I don't have Quartus here) if it recognises and accepts the file it should list all the IP that's licensed in the window below. Nial.
