15 years agoLibrary Setup broken?
Hi, I have NIOS/SOPC_BUILDER design here with libraries in the generated files not matching my library (at least I guess so). The actual problem is a component called "altera_std_synchroni...
15 years agoit might be fixed in newer versions, i'll check 10.0
do you know which component is calling altera_std_synchronizer?
