17 years agoLegacy DDR compilation error
Hi, in a project I have been working on for a while this message suddenly appeared: Warning: Atom "DDR1:DDR1_ddr_sdram|DDR1_auk_ddr_sdram:DDR1_auk_ddr_sdram_inst|DDR1_auk_ddr_datapath:ddr_io|...
17 years agoIt should be possible to disable the dedicated resync clock by going to the 'Advanced' tab and manually overided the resync phase selection.
The message "Critical Warning: Could not find 'wdata_r' or 'resynched_data' registers needed to check PLL offsets. Will continue assuming resynch PLL is set to 303" means that the script couldn't find one or both of those registers in the post-fit netlist, which is suggests that they are being optimised away. If the timing analysis completes sucessfully anyway, then everything should be fine as long as the dedicated resync clock has not been changed from the value that the megawizard calculated. Most likely a register the timing script can't do without has been optimised away too, and it will fail later on.
