12 years agoLarge Number of taps FIR implementation
Hello, I would like to know if it is possible to implement a 262144-tap FIR filter in a Stratix V? The input rate is 200kHz The input resolution is 18 bits The coefficient resolution is 1...
12 years ago --- Quote Start --- Thanks for the tip! --- Quote End --- if your fir is symmetric you can reduce by half by pre-adding then multiply. You will need many accumulators. So not a big price for such a huge filter which truely is "Mother of all Filters"
