13 years agoLAB Optimization
Hi, I've developed an IP Core, were there's a lot of logic operations (xor). All of them are done in a single clock cycle. My IP uses 35.000 LUTs out of 55.000 availalbe in my ARRIA II GX device. ...
13 years agoI have quartus 12.1sp1. This is my Resource Usage Report:
ALUTs Used 36,124 / 50,600 ( 71 % ) -- Combinational ALUTs 36,124 / 50,600 ( 71 % ) -- Memory ALUTs 0 / 25,300 ( 0 % ) -- LUT_REGs 0 / 50,600 ( 0 % ) Dedicated logic registers 5,962 / 50,600 ( 12 % ) Combinational ALUT usage by number of inputs -- 7 input functions 347 -- 6 input functions 21009 -- 5 input functions 4256 -- 4 input functions 4482 -- <=3 input functions 6030 Combinational ALUTs by mode -- normal mode 34318 -- extended LUT mode 347 -- arithmetic mode 1249 -- shared arithmetic mode 210 Logic utilization 58,120 / 50,600 ( 115 % ) -- Difficulty Clustering Design No-Fit -- Combinational ALUT/register pairs used in final Placement 37044 -- Combinational with no register 31082 -- Register only 920 -- Combinational with a register 5042 -- Estimated pairs recoverable by pairing ALUTs and registers as design grows 0 -- Estimated Combinational ALUT/register pairs unavailable 21076 -- Unavailable due to Memory LAB use 0 -- Unavailable due to unpartnered 7 LUTs 347 -- Unavailable due to unpartnered 6 LUTs 20553 -- Unavailable due to unpartnered 5 LUTs 34 -- Unavailable due to LAB-wide signal conflicts 20 -- Unavailable due to LAB input limits 65 -- Unavailable due to location constrained logic 1 Total registers* 5962 -- Dedicated logic registers 5,962 / 51,336 ( 12 % ) -- I/O registers 0 / 2,232 ( 0 % ) -- LUT_REGs 0 ALMs: partially or completely used 29,001 / 25,300 ( 115 % ) Total LABs: partially or completely used 2,906 / 2,530 ( 115 % ) -- Logic LABs 2,906 / 2,906 ( 100 % ) -- Memory LABs 0 / 2,906 ( 0 % ) Virtual pins 0 I/O pins 82 / 404 ( 20 % ) -- Clock pins 0 / 10 ( 0 % ) -- Dedicated input pins 0 / 28 ( 0 % ) Global signals 17 M9K blocks 64 / 495 ( 13 % ) Total MLAB memory bits 0 Total block memory bits 125,984 / 4,561,920 ( 3 % ) Total block memory implementation bits 589,824 / 4,561,920 ( 13 % ) DSP block 18-bit elements 0 / 312 ( 0 % ) PLLs 1 / 4 ( 25 % ) Global clocks 16 / 16 ( 100 % ) Quadrant clocks 0 / 48 ( 0 % ) Periphery clocks 0 / 50 ( 0 % ) SERDES receivers 0 / 28 ( 0 % ) JTAGs 0 / 1 ( 0 % ) ASMI blocks 0 / 1 ( 0 % ) CRC blocks 0 / 1 ( 0 % ) Remote update blocks 0 / 1 ( 0 % ) GXB Receiver channel PCSs 1 / 8 ( 13 % ) GXB Receiver channel PMAs 1 / 8 ( 13 % ) GXB Transmitter channel PCSs 1 / 8 ( 13 % ) GXB Transmitter channel PMAs 1 / 8 ( 13 % ) HSSI CMU PLLs 1 / 4 ( 25 % ) Impedance control blocks 0 / 3 ( 0 % ) Maximum fan-out 3662 Highest non-global fan-out 1696 Total fan-out 221200 Average fan-out 5.12
