11 years agojesd204b IP core have problem
When I use the altera_jesd204 IP core in my procedure ,I try to use modelsim-altera to do RTL simulations .Then I find this problem.When the modelsim compiles the altera_jesd204_8b10b_dec.v ,it find...
11 years agoHi,
Looking at the error messages, it seems like there is some internal issue with the IP .v files. Just wonder which version you are using? You might want to try the latest version to see if it works.
