Jesd204b interface seems to misbehave after upgrading quartus from 16 to 19
Thanks for your update. Please see my responses as following:
1. Mind let me know which FPGA device that you are using to interface with the ADC?
2. When you refer to sync signal toggling, mind let me know which specific sync signal that you are referring to ie from the JESD204B IP?
3. For the screenshot, signaltap and .qsys or QAR file, you may send through email to me if there is any concern posting it to the Forum. I will send you an email and your may reply to that. Please share with me further on the issue observation so that I can have a better understanding on your sync issue.
4. As for the Modelsim simulation, it is recommended for you to perform a loopback using duplex mode JESD204B IP to further narrow down the issue. If issue occur even with loopback, then we could isolate the external device.
Chee Pin
