15 years agoJESD204 interface
I want to make JESD204 interface for using LTC2274 AD converter. But I don't know which mega function to be use. Teach me how and which megafunction to be use or IP for JESD204. Thank you.
12 years agoYou can use the JESD204 megafunction, available in Quartus 14.0 and on. Mind you, you will have to pay for it (about $10K I think), and you will need to understand the appallingly written User Guide. There is an example, but it is in Verilog or VHDL only, and understanding the linkage is difficult. A proper block diagram (not the generalised one in the UG) or capture of a Qsys block diagram would have been much better.
All the same, it is now available.
