16 years agoissuing memory write request from PCI Express endpoint
Hi! I'm trying to send data from my PCI Express endpoint (StratixIV Hard IP) to the root port memory. For that I would need the enpoints device ID (to put it in the requester ID field of the he...
15 years agoPractically you don’t have to care about the contents of cfg_busdev unless you are a root port or you implement multiple functions. Just use it whenever sending a TLP. If you want to know more about cfd_busdev, look into the PCIe Specification, Section labelled »Transaction Descriptor – Transaction ID Field«. The 8 MS bits are the PCI Bus Number, then there are 5 bits Device Number, and the 3 LSBs are the Function Number.
