13 years agoIssues with Interlaken PHY on Stratix V
Hello, I am implementing a multi-lane Interlaken PHY design on a Stratix V part. There seems to be a dearth of documentation and experience regarding this IP. Specifically, I see some strange...
12 years agoRomno,
Hi, did you every solve your problems with Interlaken? Also, are you using NIOS in your design? If you solved your problems would you recommend others to use the Interlaken IP? Thanks, joe
