RamaMohan's avatar
RamaMohan
7 years ago
Issue with PCIe HIP(A10) Gen3 model behavior in simulations with serial interface
We are facing an issue in simualtions, with the data transmitted from PCIe hard-IP model during initialization while switching from Gen1 to Gen3 Speed. The model being used is the one for A10 FPGA device. Here’s the issue:
After moving Recovery.Speed state and sending TS ordered set, HIP is sending unknown symbols on Tx with HiZ on the lines.
The said behavior is seen repeatedly for a long time before HIP Tx enters electrical Idle.
The simulation has enabled fast_sims in serial mode.
Appreciate help/suggestions
RamaMohan
  • RamaMohan's avatar
    RamaMohan
    Hi Nathan, Appreciate if you can get this issue reproduced and get the fix ASAP. This is really blocking us. Thanks, RamaMohan
  • ​Hie RamaMohan,
    I believe my last update did not get through.
    I tried with VCS and still unable to reproduce the issue. Hence, without your RP BFM, I am unable to replicate the failure and de bug further.
    Nathan
