16 years agoIssue with Iperf
Hi all,
I am facing issues with Iperf when I run the device under test as UDP streamer as client and workstation as the server I get the following error at the server end: [root@localhost src]# iperf -s -u -i 1 ------------------------------------------------------------ Server listening on UDP port 5001 Receiving 1470 byte datagrams UDP buffer size: 108 KByte (default) ------------------------------------------------------------ terminate called after throwing an instance of 'std::bad_alloc' what(): St9bad_alloc Aborted Could you trrow some light on what might be going wrong here. Thank you, Suneel.No RepliesBe the first to reply
