11 years agoIs Transceiver Toolkit compatible with 8B10B encoder/decoder ?
Hi, I want to test a transceiver link on a Stratix V GX SI Dev Board. Firstly, I have successfully run the altera design example "sv_4ch_32b_6445mbps" with Quartus II v13.0SP1. Then, I have...
10 years ago --- Quote Start --- Hello, if I am experiencing the same problem and I have reached the same conclusion, am I doing something wrong? I am using a Cyclone V so I am not looking at eye diagrams, just link ber. Thanks in advance --- Quote End --- Hi, I made this post a long time ago and now I'm working on different subject... so it is difficult to remember... As far as I remember, 8B10B is problematic for Transceiver Toolkit. However, I may found a functional test configuration using the "serial bit comparator" mode... Sorry for this poor support... Bye Mike
