11 years agoIs there an easy way to establish static reconfiguration of transceivers (VOD etc)
Last time I did an FPGA (Stratix IV) you could set transceiver analog properties (VOD, preemphasis etc.) right in the Megawizard. This was convenient if you did not mind re-compiling each time they w...
11 years agoI don't have a host PC, and I don't want to have to create one (NIOS) and then have write software just to initialize VOD. My target application involves no processor whatsoever.
There must be an easier way. I see that there is a way that involves having config data in a MIF, but I don't see how to create the MIF file. Is there some tool that lets you select configuration (VOD, preemphasis values etc) and build the MIF for you? I can't believe that I would have to paw through a memory map and hand edit a MIF file. Thanks
