A more detailed description of Triple Speed Ethernet's PHY part spells "1000BASE-X/SGMII PCS With Optional Embedded PMA". For other media an external PHY is required. Just review the Triple Speed application examples.
Apart from the clear description of the IP core, the answer is also obvious when considering the required hardware features of an ethernet PHY. - Altera_Forum
--- Quote Start --- I can not get the detailed info and the source code of the PHY IP core used for cyclone II. --- Quote End --- Can you tell us the manufacturer and part number of the fibre optic transmitter? - Altera_Forum
I got the confirmation that the PHY (a Serdes module) is developed by ourselves.
The fiber optic transmitter is QFBR-5750APZ supplied by Avago
