17 years agoIs the pin assignment changing right?
Hi, I have designed a ddr2 interface using StratixII, and been confused about pin assignment. The IP Core Tool Bench assigned the pins for ddr2 sdram automatically. In order to make the ...
17 years agoherezt is refering to the fact, that the RAM address pins must be connected in the correct order, otherwise the RAM controller can't work. This wasn't doubted at all, because the discussion was regarding changes to the pin placement, not changing the pin assignment between RAM and RAM controller.
