17 years agoIs the pin assignment changing right?
Hi, I have designed a ddr2 interface using StratixII, and been confused about pin assignment. The IP Core Tool Bench assigned the pins for ddr2 sdram automatically. In order to make the ...
17 years agoAddress pins can be exchanged? The initialization needs to use the address pins. If the order changes, will the initiall parameter be wrong?
