12 years agoIs it save to use the PIO in QSYS
Hello, I have several PIOs in my QSYS design to communicate with some of my own designed IPs. My IPs mostly use other clock signals than the PCIe-Clock and are therefore not synchronized to t...
12 years agoFirstly counting pulses asynchronously is a bad idea. You should synchonise the pulse to a clock and then count the transitions on the next clcok edge.
Secondly data is moved between clock domains it must be put through a multi-stage synchroniser. Qsys will add one (transparantly) between avalon masters and slave. Thirdly any such synchroniser can only synchronise a single bit - you cannot move the output of a ripple counter between clock domains. So you either need to count in grey binary, or just transfer the LSB and count in the target domain.
