15 years agoIs it possible two DDR2 controller use the same PLL?
Hi, I wonder that if two DDR2 controller can share a PLL on a CYIII. For example, Run a PLL outputting 166MHz for two DDR2 controller. I noticed that a option called "use clocks from an...
15 years ago --- Quote Start --- Here is the external memory handbook http://www.altera.com/literature/lit-external-memory-interface.jsp --- Quote End --- Hi, std_logic Thanks a lot for the link! I will check it out. Thanks again!
