15 years agoIs it possible two DDR2 controller use the same PLL?
Hi, I wonder that if two DDR2 controller can share a PLL on a CYIII. For example, Run a PLL outputting 166MHz for two DDR2 controller. I noticed that a option called "use clocks from an...
15 years ago --- Quote Start --- Sharing PLLs is possible, as long as the frequency is the same. Just select the option and wire up the other PLL to it in the RTL --- Quote End --- Hi, Thanks for reply! I understand your point, but how to wire up? Is there any docs on this subject I may refer to? Thanks again!
