13 years agoIs it possible to "gluelessly" connect several Altera IPs via Avalon-ST interface?
Hello! Is it possible to "gluelessly" connect: - Clocked Video Input/Output IP ( from VIP suite ) - Altera SGDMA IP - Altera PCIe x 4 Hard IP between each other via Avalon-ST interface...
13 years ago --- Quote Start --- From: http://www.altera.com/literature/manual/mnl_avalon_spec.pdf Page 35: "All Avalon-ST source and sink interfaces are not necessarily interoperable. However, if two interfaces provide compatible functions for the same application space, adapters are available to allow them to interoperate." --- Quote End --- Does that quote means, that inserted Avalon-ST Adapters ( in the attached screenshot ) are in fact "Avalon-ST Video -> Avalon-ST" converter blocks ?
