13 years agoIs it possible to "gluelessly" connect several Altera IPs via Avalon-ST interface?
Hello! Is it possible to "gluelessly" connect: - Clocked Video Input/Output IP ( from VIP suite ) - Altera SGDMA IP - Altera PCIe x 4 Hard IP between each other via Avalon-ST interface...
13 years agoNo, it is not.
SGDMA streaming input/output does not know anything about Avalon-ST Video (VIP suite) protocol. Read this: http://www.altera.com/literature/ug/ug_vip.pdf See page 34: "The MegaCore functions in the Video and Image Processing Suite use the Avalon-ST Video protocol. The Avalon-ST Video protocol is a packet-oriented way to send video and control data over Avalon-ST connections. Using the Avalon-ST Video protocol allows the construction of image processing data paths which automatically configure to changes in the format of the video being processed. This minimizes the external control logic required to configure a video system." The Avalon-ST video protocol is a subset of the Avalon-ST protocol. There are various kinds of packets that are defined by the VIP protocol that you must handle appropriately. The SGDMA block knows nothing about how to parse these. That is why you need an Avalon-ST to Avalon-ST Video converter block if you want to connect anything from the VIP suite to the SGDMA.
