12 years agoIs DSP Builder intended to be used in design a product?
Hello, my name is Jaime I am envolved in a development of physical layer blocks of a digital TV system. At present I am coding in VHDL but I evaluating to use DSP Builder to reduce development tim...
12 years agoHello ,
I believe the dsp builder is integrated into matlab which allows you to generate Hdl code for quick designs. From experience, it's an ok tool for testing . Designing in hdl will allow you to make a more optimized design and better understand the dsp concepts. I think you should explore the mega wizards further before trying the dsp builder. Btw hdl coder is available for matlab which have better performing dsp cores if interested.
