14 years agois DDR controller support 64M single chip?
I have some doubt about DDR memory controller:
I found the ddr controller doesn't support 64M bytes(32M X16) single ddr memory chip, can I modify the address lines of this IP? I add a ddr controller,but why my SOPC doesn't require a PLL for memory controller? by the way quartus warning: 1. Info: Pin write_clk_to_the_ddr_sdram not assigned to an exact location on the device, But I can't find this signal on memory chip. 2. Warning: Setup slack is -6 ps associated with pin 'ddr_dq_to_and_from_the_ddr_sdram[4]' ( variation port 'dq(4)', 'input_cell_L[0]') ( Total of 2 paths with negative slack) thanks for helping me.No RepliesBe the first to reply
