11 years agoIs clock neede in DSP builder design?
Is it necessary to add a clock in DSP builder design?
11 years agoYou need to use a clock block to derive the clock rate, else it will just assume it is running at 50 Mhz. You wont find any clock pin in the design, but after you have compile it, from the top level VHDL file, you will notice there is a clock input pin that required to connect to a clock source from hardware.
