13 years agoIP Security with DS28E01 and Cyclone 4E - Altera Reference Design Integration Problem
i try to integrate the Reference Design into my Design. I use the Dual-Purpose Pin "flash_nce/ncso as regular i/o after configuration" for the One Wire Interface. Externally i have an Pullup Resistance for One Wire Inteface (also the pin flash_nce/ncso). Firstly i use the "load_secret_key_ds28e01.mif" file for Secret Key Load to the Security Memory and program the .sof - file on FPGA via SignaltapII. I assume, that the Secret Key is now programmed in the Secure Memory. Secondly i use the "enabler_ds28e01.mif"-file with the hope, that i will see the "enable" Signal goes HIGH after FPGA-Configuration and the SHA1-Engine is done. After SHA1-Engine Reset i see in SignalTap2, that the statemachine in designfile "small_micro_32.vhd" does somewhat, but the OneWire IO always stay LOW and hence the "enable" Signal always LOW too. Has someone succesfully used this Reference Design? Maybe i will try to use one normal IO for Onewire Interface... The Reference Design is here http://www.altera.com/support/refdesigns/sys-sol/indust_mil/ref-des-secur-mem.html Thanks in Advance! Cheers Tomy
