14 years agoIP Purchase
Good morning.
Understand that OpenCore IP must be tethered unless IP is purchased. When I use Quartus programmer, it indicates that I have two evaluation IP cores: Vendor 6af7 Product A2 Vendor 6af7 Product BD Reviewing the info/warning messages, it appears that these are the Altera NIOS and Triple speed ethernet cores. It also appears that these can be purchased as part of Altera's IP-EMBEDDED product. Just looking for confirmation that I am buying the right thing and that the IP-EMBEDDED purchase will allow me to create and non-time limited SOF (and subsequently POF) file. Thanks, in advance, ME2 Replies
Yes those two cores are indeed the Nios and TSE. If what you are reffering to is the IPS-EMBEDDED suite described here (http://www.altera.com/devices/processor/nios2/ipsuite/ni2-ip-suite.html) then it should cover those two.
Define "dynamic IP". I don't think what we mean by "IP" in this forum is what you mean.
